Built Comanche Rebuild
I've had a shoe come apart before as well. Not pretty. I assumed it was from someone leaving the parking brake on & driving away.
They were bonded shoes and seperated from backing plate. It wasnt terible, that wheel of brakes started locking up, which is interesting in the rain with locked diff. But got it sorted out and actually took it wheeling today and finished off some of the bushings
That's the bad thing about shoes on drums. Lots of shops told me that on occasion (cheaper shoes especially) they will come apart if you slam immediately on the brakes.
Its usually a defect, very worn or abused (ie ran hot, over adjusted etc) bonded shoes that seperate. These shoes were just worn and had been soaked by gear oil or brake fluid at a point in time. But new ones are on and shes stopping good now
so tinkering with the manche today tring to track down "clunk" I hear while driving starts at 10 mph and either stops or just cant heare it above 40.
I had the rear end lifted and found there is aproximatly 1/8 inch play in and out on the rear axle shafts.
But rotating assembly by hand or w/ in gear produces no noise, same w/ front axle
Atleast you have your priorities in line! We had a good time. Nothing broke,just an overheated XJ one kid was beating on. We're going back Dec 7-9, bring this thing on out.
Sent from my MB855 using Tapatalk 2
Tore into rear end to track down clunking noise. I knew axle bearings are bad so I have them on hand. But when I opened up the cover my heart sank. The p.o. thought it hade welded spiders and having peaked thru the fill hole I thought it so myself. Turns out it has a lunchbox type locker that had broken the pins and a section of one case half. Well at some point someone had welded the two halves together and now those welds have broken apart. So I reckon I'm going to pick up a spider gear set unless a dirt cheap locker pops up soon
