frankenyoter
No Rain, No Rainbow
- Mar 17, 2009
- DARK CITY
9.5” party set with all the fixins!
FJ60 front (set up for spring over mini truck)
-cut and turned axle with truss (built by race car axle guy - it’s perfect)
-original Longfields and hub gears and ARP studs
-Marlin high steer with hydro assist
-Marlin trunion eliminator kit
-DOM drag link and tie rod w GM 1 ton TRE
-triple drilled flange pinion flange
-new rotors and calipers (when assembled)
-Lockrite
-5.29 Yukon gears (Carolina Axle installed)
-includes u bolts and plates
FJ80 full float rear (set up for spring over on mini truck - I’m running Chevy 62s)
-new wheel spacers torqued and checked several times post assembly
-welded third
-axle wrap bracket
-triple drilled pinion flange
These got all the good Marlin bearing, seals and wipers when assembled.
Current setup will do 60 mph w 40s while steering with one hand, no shakes or vibrations and even tire wear. It’s only been in the woods one trip to Windrock and a few logging roads around town.
Axles are still under the truck, but coming out soon or can pull earlier with a few days notice. I can have a machine to help load. Delivery negotiable.
You could bolt these in one weekend and rule the trails next weekend.
Located in Black Mountain
$2,000
-Lockrite
-welded third
-axle wrap bracket
$2,000
