UNBREAKABLE
- May 19, 2005
- Granite Falls
Ok, so here's the deal...a couple of weeks ago I sold my '03 CTD 3500 Dually and I've been wanting to do a Cummins swap into a Ford. Well just a few moments before I sold my Dodge I found my truck to swap...'99 F-550 XLT 2wd. 4.88's 7.3 w/ 204K on it, crew cab..nice looking truck. Well, the deal was that a guy in Iraq found the truck online and had his wife go buy it..well, she drives it for a few days and then it starts acting up, she has to have a hauler and they don't want to fool with it so he sells it to try to recoup some of the lost funds. I buy it..it was at a garage in Oklahoma(I'm in NC). I start talking to the garage guys(who rightfullly seem knowledgeable). When it came into their shop it was 8 quarts low on oil(it had just had the oil changed). OK...So I asked them to poke around and see if they could figure out what was wrong with it. Fast forward a bit and they find an injector sensor bad. Fix that...still won't run right. Then they find that it's not getting the right amount of fuel pressure. Drop the tank, clean the filters, replace the fuel pump...truck runs like a champ. I ask about the oil problem..they say it looks fine now.
Last Friday morning I fly out to Dallas, get in a cab and go to Durant(where the truck is). I get there...the truck is in way better shape than I honestly figured it would be. I pay the garage and get some paperwork from the owner's wife and then set out for NC. I stop about 60 miles from the garage and fill up with fuel...figure, what the hell..I better check the oil(truck has not smoked at all). I pull the dipstick out...not registering(****). So 2 stores down is an O'rilleys. I go in, buy a case of rotella. Pour in a gallon..and I'm back on the road. I stop 100 miles later...pour in another gallon of oil. I do this ALL THE WAY HOME! IT TOOK 12 GALLONS OF OIL TO GET HOME!
Now..all the while driving back I'm calling all my diesel buddies and picking their brains. "O-rings, Turbo, oil cooler going into radiator". Well, the truck is at the dealership and guess what...it has 3 new injectors..a full set of BRAND NEW O-rings, New under valve cover harness---ALL FROM THE PREVIOUS OWNER. Apparently, someone has already been chasing this demon. It does however have 2 hpop fittings that are slightly leaking(not 12 gallons though).
Compression 500 on all cyls. Injectors all testing fine. Injector cups look fine. No nicks on o-rings.
ANY IDEAS!
ANY IDEAS!
I gotta ask, why did you not just keep the dodge? Was the whole reason that alot of dodge people say "good motor, disposable truck"?
