Here are some pictures of my shock out boarding project this weekend.
I drew up some designs for some recessed shock mounts based on some I found online. I contact Mud at
www.MudProMetalworks.com to cut out and bend up my design. As always he exceeded my expectations. Mud is located in Hickory NC and is a prefect source for your tabs, brackets and customer designed parts. Check out his site.
First i measured and cut out the frame rail.
This is what it looked like, there was a lot of eye balling and measuring, but I got it. I cut it out with a grinder and cut off wheel.
I had to prep the axle for the bracket, I went ahead and cut off my old brackets.
Here is a picture of the mount mocked up in the cut out. You can start to see my plan.
My fit looked good so I went ahead tacked it in place as well as the axle bracket to see how the shock looked in place.
Alignment looked well and it cycled up and down with out issue. So I burned it in. I incorperated a couple gussets to support the load on the frame.
Primed and painted everything.
I am going to correct the over spray next weekend with some under coat in the wheel well
Here it is with the tire on, this turned out pretty nice.
Going to test it later, still got to mount the gas tank back in and clean it up. But it was a good weekend.
