Buying Tires D or E what to buy?
JonBoy
Hampstead NC
Ok im buying 265/75-16 tires you can get them in a D or E rating. I know that one will hold more weight than the other but is there some reason to get the lesser rated tire? ride different? they are pretty much same price like $1 difference. Nitto AT or BFG AT
Its going on 98 chevy full size, ex cab, 4x4, but 5 speed no power windows/locks, bench seat and only the 305 so it prob is a little on the light side.
correct me if i am wrong but i think the rating determines what the maximum speed is the tire can handle, i would go with the e rating.
on passenger (P-P175/55/15) tires i think they are for speed, on light truck (LT-LT265/75/15) tires, i think it is for load rating. i think that it is more of a towing rating more than anything else.
B-F are load range ratings (M-Y are speed ratings). D are 8 ply and E are 10 ply. D are 65 psi and E are 80 psi. I had E's on my Suburban once and the tech said I could run them at 70 and it would give me a smoother ride. I don't know about the smoother ride but just like running any tire under pressure the tread wore on the outside faster than the inside. I have different E's on my burb now and I like the way they handle. I don't really like airing them up to 80psi though. Sounds like you could go with either and maybe not know the difference.
You'll be fine with either, thought the E rating will be a stiffer sidewall and tread construction to better handle the weight. For comfort, I'd go with D.
Just my $.02
The only true way to tell load capctiy is with the load index, service numbers on a tire... load rating is really an older scheme when actual rubber plys were used, its a good indication of capacity and ply 'rating' but not actual plys used.
A tire with 2 ratings is for its rating when used in a dual applicatoin,
for example my D - rated BFGs are 119/120 a dual would be 119 (each) and my Single tire would be rated at the 120 value.. (at the spec'd PSI)
65- 639 lbs
66-661
67- 677
68- 694
70- 739
71- 761
72- 783
73- 805
74- 827
75- 853
76- 882
77- 908
78- 937
79- 963
80- 992
81- 1019
82- 1047 83- 1074 lbs
84- 1102
85- 1135
86- 1168
87- 1201
88- 1235
89- 1279
90- 1323
91- 1356
92- 1389
93- 1433
94- 1477
95- 1521
96- 1565
97- 1609
98- 1653
99- 1709 100- 1764 lbs
101- 1819
102- 1874
103- 1929
104- 1984
105- 2030
106- 2094
107- 2149
108- 2205
109- 2271
110- 2337
111- 2403
112- 2469
113- 2535
114- 2601
115- 2679
116- 2756
117- 2833 lbs
118- 2910
119- 2998
120- 3086
121- 3197
122- 3307
123- 3417
124- 3527
125- 3638
126- 3748
127- 3858
128- 3968
129- 4079
130- 4169
131- 4299
132- 4409
133- 4541
134- 4674 lbs
135- 4806
136- 4938
137- 5071
138- 5203
139- 5357
140- 5512
141- 5766
142- 5842
143- 6008
144- 6173
145- 6393
146- 6614
147- 6779
148- 6944
149- 7165
150- 7385
