kinda.. i can give some pointers on what to do and what ull run into. what type of motor is it and what tranny is behind it now. c6 will swap into any 300, 302, 351w, c6 is way shorter than newer trannys so crossmember is going to be modified or comes with the c6 tranny. might have a problem with lines hooking up and u gotta check on the flywheel depth. and the most important thing over looked. will the started turn the motor. teeth maybe a problem. but other than that it should be easy. maybe not a dd unless u take ur time and measure everything. this should help
