tkeaton
Master Velocipede Alchemist
- Mar 20, 2005
- Chattanooga
I have a bit of a ditch that is crossed by a fallen log. The ditch aint real small. There are unquestionably solid trees on either side of the span. The width of the span is 100-120 feet.
I am wanting to run a cable between the two trees on opposite sides of the span. The idea is to harness in and attach a tether to the cable spanning the gap.
What is the minimum diameter/construction type of cable that I should use? How taut should I attempt to get the cable? What is the best method for securing the cable to either side of the span?
Only one person at a time will be tethered to the cable. Maximum weight of 200lbs. Cable will not be under external load, unless person crossing the span falls off of the log.
