I contend that with the map upnover posted a 1st timer would have little problem hitting the hot spots! Some of the trails are marked with pink dayglo. Red is #2, yellow is 4, green is 1. Yellow/Red rock garden is marked TOW, The Tower, aka 360 is just past TOW on trail 4. Welder entrance is plainly marked "3", drop down off the green trail to the right where the Little Tellico sign is and with the map in hand you can't miss Armor All, Little Tellico and Pull Cable. The recommended loop IMO would be to take the red trail (2) from the red/green junction up to TOW, then to 360, follow yellow (4) down to green (1), go up welder (3) to the top, take the rut trail back down to Easy Out and then take The Step back to blue, blue down to green and then green over to Armor All, Little Tellico and Pull Cable, back track on green back to the campground. This route would allow you to see most of the park, hit all the hard spots while allowing any vehicles that want to to bypass the obstacles. This can all be done in one day if you take the bypasses and don't have any breakage
