Calling on the jeep guys
old guy
home
I have a 2000 Grand Cherokee 4.0 with a busted block, and I have a 1987 engine from a Cherokee. My question is will the short block from the 1987 work in the 2000? It would appear that everything will work the question is the crankshaft. thanks in advance for all the help.
old guy
In my opinion you are best finding an identical block. There are motor mount differences combined with accessories mounted differently on the front serpentine belt.
Short answer is...no.
The WJ engine will have cast in motor mount bosses in a deifferent location than the early 4.0
There's some other issues but that one is a biggie.
I have a good running 4.0 from a 99 xj for sale. If you're interested shoot me a pm. Located in Lincolnton.
Iirc, 99xj has different motor mount locations from the wj.
Quoted from above posted link
99-04 Jeep Grand Cherokee WJ 4.0L
99-04 WJ, 00-06 TJ - 2002 and up were TUPY heads and did not have the cracking problems that earlier 0331 heads had. 02+ are recommended.
I said was for sale, not that it would fit. One needs to do their own due diligence..;)
Thanks to all for the info. Got the early engine on the stand and after getting the head off of the later engine I got a better look at things. (the 2000 is still in the vehicle). Yes accessory mounts in different places. can anybody use a 89 4.0 need going thru. Casting number is 53005535. Located in Maryland. need to help fund rebuild, make an offer.
