ncgamedog
- Oct 30, 2005
- Greensboro, NC
Guys I'm collecting parts to complete my 355ci SBC. Right now I have a 5.7 liter TBI series block bored 0.030 over with stock turned crank, stock rods, and new flat top pistons. The hydraulic roller lifters were gone when I got the block so Im planning to just use regular hydraulic lifters instead...if that will work? Does anyone know if that's ok to do with these blocks or if there is a source to get new rollers cheap?
Im also trying to find some heads that will work well with this setup. The engine is going in my 68 chevy project 4x4. It will mostly see low RPM's and be used for cruising around the farm, or country, and some light to medium towing (under 10000-8000 lbs). I want to be able to take a few road trips with it and will eventually add AC. I say all that cause I want to build power in the right range and keep the engine cool under those conditions. I am thinking about some early castings with smaller valves to create more torque, and somewhere around 70-76cc chambers. Im thinking I should be shooting for around 9-9.5:1 compression ratio. Def would like to be able to run 87, but at least pump gas. Im also thinking abt an RV cam of some sort. I will be using an edlebrock performer intake and most likely the stock quadrajet carb, rebuilt. I might be persuaded to go to an aftermarket head if its really worth the extra coin. Other information that may be important is that it will be running in front of a th400/205 and the axles are geared 3.73. Will be running around a 33" tire, either a 285/75/16 or a 255/85/16...maybe even a 750-16 lol. I want this engine to work well and come together correctly, and not just end up as a pile of parts. I know there are a lot of factors to consider so I'm throwing all this out there in hopes of some experienced guidance. Thanks for any input you guys can provide on which direction I should go and what parts to look for.
