Granny
One day at a time...
- Jun 12, 2007
- Cabarrus County (Rimertown)
This may be a trivial question, but I am wondering about how long the battery might run the furnace in my popup camper before needing charged. The furnace is a Suburban 17,000 BTU Propane. As best as I can figure, it needs a little bit of juice to hold the gas solenoid open, and it has a 12v blower. Allowing for minimal usage of lights, water pump, etc., what should I expect? I'm sure some of you RV owners have a pretty good estimate on this. ThanX!
For what it is worth, the following is the battery data:
Duralast (Autozone) RV Deep Cycle Battery
Cold Cranking Amps - 550
Marine Cranking Amps - 685 @ 32°
Amp Hours - 85
Reserve capacity - 140
Amp Hours - 85
