I noticed fuel leaking out of my 6.2 diesel today. I thought it was the inlet hose to the mechanical (block mounted) lift pump, even though the hose itself was not wet. I tried to tighten the clamps but one stripped out. After replacing both clamps, it is still leaking, and definitely not from the hose.
This is a block mounted fuel pump just like what you'd see mounted to any carbureted V8.
The body of the pump is wet and drips of fuel continually form on it. Can the pump itself leak, not from a hose connection? I can't see where it would be coming out of the pump, but at the same time, I can't see any other place the fuel could be coming from. I can't see anything that could be leaking this fuel onto the pump. It is not coming from the hoses, it is actually on the round part of the pump *above* the hoses.
I just want to make sure before I pull the pump that it's really the pump leaking, and not something else.
I've heard of the fuel pump leaking fuel into the oil, but never the pump leaking outside itself.
