trailjeepman
- Jun 7, 2005
- Raleigh, NC
Can I relocate an oil pressure sending unit to another location or position by using copper fittings? In other words....does it matter what direction the top of it is facing? My problem is, that I am replacing the motorcraft alternator with a delco on the 360. The back of the Delco alternator is hitting the sending unit, because it is thicker. I took the sending unit off and plugged the hole temporarily to see if I could get the alt to fit and it did. Any other suggestions are welcome as long as I can get out free or very cheap. Maybe I need a different set of brackets or something. If you have a set, let me know!
Thanks!
Thanks!
