MGWJeep
- Oct 29, 2011
- Germanton,NC
Replaced my fuel pump, fuel filter, and fuel pump relay today. Still can't get fuel to injector rack. Has anyone had a similar problem?
is there spark?
check for 12v to the pump using the chassis as a ground. if you have 12 volts then id just run a second ground to the body or chassis. did you check the fuel pump relay... theyre pretty common to burn out. if no 12 volts then check at the relay location for 12 V
Great info brother! I saw the ballast resistor, but wasn't sure what it was for (dang new-fangled JeepsAs said fuel pump relay. When you turn the key do you hear the pump come on. You should. As he said check voltage at the pump.
However, a '90 has a ballast resistor on the driver side front fender right next to the air box. The purpose of this is to knock down the voltage to about 6-7 volts. This was mainly done due to the noise of the pump. Ballast resistors are ceramic and are known to crack. This makes the fuel system not function. You can just bypass these, however you'll hear the pump more. Later xj's do not have the resistor.
So all this and it ended up being a dead battery?
I recommend biting the bullet and buying new injectors.
