orange150 said:
So I have to unbolt the torque converter from the flexplate? makes since... does it matter if the starter is still bolted up?
Umm, yeah, the starer bolts thru the plate between the engine and trans ( which is also bolted to the engine
) thus the starter is keeping the works from moving.
and you have to pull the starter to get to the conveter nuts ( I think Ford uses studs on the converter ) when ya got them all out, you can push the converter to the rear a bit to clear the flex plate, and the converter should spin free.
Just be aware that the converter can and will fall out and make a huge fluid mess if you are not careful. If all this mess is still in frame, support the trans with a jack before you yank the engine out ( also helps position things for easier removeal )
PS, since you already have all the tranny bolts out, either replace 2 of them BEFORE you pull the starter, or support the trans with a jack, soon as you remove the starter bolts, it could slip out, even with the converter still hooked to flex plate. again making mess and possibly small parts that can't be reassembled.
Kevin
