LarrySmith89
- Mar 18, 2008
- Conway NC
Got a remanufactured. Thanks for replys.
flooding how ?
one cyl ( #1 ? ) or flooding all cyls ?
if it is only flooding No.1, there is a Diaphragm that has a pin hole in it, is called the Aux Accelerator Pump ( AAP ) this is a common on carbed 20-22R engines, will foul #1 plug as a result.
You used to be able to by the diaphragm seperately, but now it only comes in a rebuild kit.
pull the vacuum line off the diaphragm on the side closest to the valve cover, while the engine is off. if fuel dribbles out, this is your problem. if you follow that vacuum line, you will see it ends right above No.1 cyl intake runner.
though being 20+ years old, it's probably time to total rebuild anyway. DO NOT loose the washers sealing the fuel cut solinoid, or toss anything until you are done, you may have to reuse some stuff, as it may have been omitted in the carb kit.
Good luck !! I fawkin hate carburators !! Aisin carbs especially !!
