Carpet Q's
RatLabGuy
Churchville, MD
I have a previously-flooded basement room (issue resolved) that needs to either (a) have the carpet re-stretched and tacked into place, or (b) the single sheet of carpet replaced w/ the piece-together carpet tiles. The advantage to those being that I can put them in myself, and look kinda cool too.
How much am I looking at either way? Space is around 250 sq ft. How cheaply can (decent) carpet tiles be found?
FWIW, the tack strips were glued to the slab, and didn't hold w/ the moisture... it'll be a pain for me to fix them into place the right way (drill and anchor, slab waaaay to old/hard for typical nails) prior to re-stretching.
Carpet is a pretty nice berber.
My in-laws own Elkes Carpet One in High Point you can call them and they would be glad to help out in anyway
Hey Dave...I am a flooring man. I can fix you up just give me a call. Carpet,Hardwood,laminates,vinyl,...if you walk on it, I can lay it.
While your over this way...
I have a couple spots the carpet either stretched or was put down uber loose and needs to be tightened up. The bad part is 2-3 of these at doorways with bottom taped seams... do you have a carpet iron?
:popcorn:
:popcorn:
Does a bear :poop:in the woods?:flipoff2:
You guys get together and we will figure a date to take a look at both houses. If they are close enough together.
I need to have my kitchen tiled while you're over this way :)
Hey guys, if yall are super serious, shoot me a pm or call me. This is my livelyhood so I can/will do the work. I will scedule a time to take a look at all of it. All work is fully guaranteed and and I have full Insurance. Dylan 336-413-0720 ''For the floors''
