What is the carrier break for a 60 rear.I have a 60 from a 2001 e350 van with 3,55s.And I want to go with a 6.17 it has the tone ring for abs if that matters.
carrier break is btwn 4.10 and 4.56, so you would need a 4.56 and up carrier. We do have thick cut low pinion gears avaialbel this is a new product however only as deep as 5.38. A 6.17 would need a new carrier. If you want to retain the abs tone ring you will need to buy a compatible carrier if your no longer using ABS then any dana 60 carrier will work.
