obullfish
Carolina Trail Blazers
- Nov 21, 2011
- Candler N.C.
anyone around WNC that tunes CB's? I know nothing about Getting some range out of the one in my TJ. It will only push about 100'.
Best thing I ever did on cb,s is goi g to the newer digital ones, such as th uniden 880 and others.
All of your tuning is done on the radio itself and is very simple. I have evn set them up to work with not ao great antenas in less than ideal places. You can esentially retard the radio to a bad antenna.
When we as a club are wheeling it seems to reach much further than most.
Also the ground you are using may or may not be a good ground
I totally missed the nylon washer. That means it's a NGP antenna, which iirc has a special type of coax that works with it. Maybe possible the coax in the jeep is not the correct type for this antenna?
