center pin in leaf springs
YJscott
Charlotte
im putting 3.5 Bds springs on my YJ and my old springs had a shim on them, i took the shim off but i need to get longer ones.
where do i get them?
you need shorter center pins you mean?
just go to lowe's and buy a grade 8 bolt with the same shaft diameter. use your grinder to round off the head that sits in the spring perch :)
i meant i took the shims off the other ones and am trying to put them on the new springs.
the ones that are on the new BDS are not long enough to go through the shim,
would i put a nut on both sides of the bolt? bc at the bottom of the spring there is a nut, and above the spring the round part is bigger. so how would i keep the bolt tight?
Locktite? Prick the trhreads to get a lock nut effect. Try using lock nuts?
Call around to the auto parts and ask for a 4" or 6" center bolt for your leaf springs. The BDS springs come with 5/16 center bolts. Now would be a great time to upgrade them. I drilled mine out to 3/8" but I have broke one already. I would go ahead and upgrade to 7/16" bolts. Drilling them out takes some time, but well worth the insurance. The new center bolts will be too long, so put them together and cut them off. Hope this helps.
just buy a grade 8 bolt of whatever lenth you need and make the head round with your grinder so it'll fit into the spring perch. no sense in making it harder than it has to be.
Socket head bolt to fit.
You know...the bolts that use an allen head wrench.
No grinding needed.
Matt
Like Erik said, go with a bolt. Center pins are made out of cheap metal... I don't know how many of them I've broken some way or another. Once you get your spring plate and u-bolts tightened down, it really doesn't matter.. but if you don't want it snapping when you're trying to do any other work to your springs, just go with a bolt.
thanks guys i picked up a center pin yesterday at carolina rock shop and now my rear is complete
