jlshermanjr
Member
- Mar 10, 2007
- brevard nc
I have my own home improvement busisness. We do all kinds of work, siding, windows, roofing,
remodeling, new construction, hardwood flooring, ceramic, plumbing and a little electrical. Basically everything except masonary and concrete. This is my problem. On the last 2 jobs where I done ceramic tile, The tile did not want to stay down. The first job was a kitchen that we gutted and remodeled. We removed the old partical board, down to the original oak planks layed on a 45 degree angle. On top of the oak planks, used liguid nails under Advantech (3/4") and nailed down about every 10" square. Then we added 1/4" Hardy backer, liguid nails and nailed every 6"-8" square. I used the Grey Megabond from Lowes, didn't hold. The house had heat and the tile was in the house for several days before. I had to go back in and take all the tile up and pressure wash the back side to get it clean. None of the tiles broke in the process. Relayed 300 sq ft of tile for free. I used the expensive premixed thin set from Lowes the second time. Haven't heard of any more problems yet. The 2nd job was remodeling 2 bathrooms. Gutted the baths to the joists, and layed 2 layers of 1/2" plywood, liquid nailed and nailed. Then 1/4" Hardy backer liquid nailed and nailed. I used the cheaper premixed thinset from Lowes this time. The house had heat and the tiles were in the home for several days. Each of the baths hed several tiles that came loose. We stayed off the tiles for more than 24hrs. On both jobs the tiles came up without breaking any of them. You can see the Backer imprint in the thinset on the back of the tiles.
All the thinset was on the tile and none on the backer when I got them up. The only common
thread is the 1/4" Hardy backer. Is anyone else having this problem? I'm looking for ideas.
HELP!!!
Thanks Johnny
828-883-7375
HELP!!!
Thanks Johnny
828-883-7375
