Had my SES light come on two or three weeks ago. Bunch of question asking and visit to Ford dealership later I get to this point. Tech said #5 injector was showing bad. Ohmed them out showed good yada yada. Took valve cover off, harness still had good connection. Started disconnecting each injector. #1 & #5 made no change in how the engine was running when I unplugged them, #3 & #7 made the engine stumble when unplugged. So I came to the conclusion my #1 & #5 injectors are bad.
Buddy had some spare injectors that he removed from a good engine (AD code, mine are AB) he said I could try. Took out #5 first and let oil/fuel run into cylinder. Waited a bit to let mixture empty out of rails. Cleaned out injector cup and used a vacuum pump to suck out most of the oil in cylinder (got about 15-17 ounces out). Coated new seals with oil and installed my "loaned" injector continued on to #5 did the same (barely any oil ran into cylinder). Turned crankshaft over by hand three times (moved freely). Took fuse #30 out (so it wouldn't fire up) and turned engine over for two 5-7 second cranks (turned freely, no hydro lock going on ). Changed out all four glow plugs on passenger side at this time. Put fuse #30 back in and attempted to start. Probably tried cranking it 12-14 times over a 2-3 minute period (no more than 15 seconds for the longest attempt). Batteries started dying so had to quit trying.
How long before this thing fires up? Any thing I can do to purge the air out besides cranking on it (I assume the air in the system is why its not starting)? It's always fired up pretty quick so I'm stumped. HELP!
