Changing Toyota universals
liftnaleg
Newton
I know this seems elementary, but did a search and cant find anything on changing universal joints...i'm getting a vibration and I thought I would start there. I know there should be a C clip someplace but mine seem solid on all four sides. Do I have to pop the caps off to find the C Clips?
the c clips are on the inside of the cups. not the outside.
clean off the dirt and you will see them.
if you have a new one you can see the groove on the cup that the clip goes in.
pretty self explanetry after that.
piece of cake to change a u joint on a toy.
On that runner I think the vibration is more of an angle problem, not a bad joint. When me and my buddy built that thing we never got around to putting a c/v joint on the driveshaft.
You need a c/v on the transfer case end and that should fix your problem.
It does have a joint on the end kinda like a ball joint...i thought that was the CV/ If not do you have one or know where to get one? I would have to shorten my DS wouldn't I. There is no room ot compress it more now.
