GoneMuddin1
- Jul 3, 2006
- Concord
I've got a new problem that I'venever run across before with my '81 K30 not charging correctly.
I've got 12.5 volts at the battery while the truck is running, 12.5 volts at the red wire in the connector at all times, 0 volts at the brown wire with the ignition off, 17 volts at the brown wire with the engine running, and 52 volts at the alternator output.
I've checked for blown fuses, but all in the panel are intact.
Hopefully someone has run across this before.
Brandon
Brandon
