covey88
- Dec 15, 2012
Ok so for some time now I have been trying to figure out this check engine light issue. I keep getting a p0441 code, I moved to Leland from Ohio (no e-check in the county I lived in up there, so no worries about the light) and I need to get it fixed to get it inspected. I have replaced all bad vacuum lines that I could find, replaced gas cap also. It made a 13hr drive with no check engine light, then once I get in stop and go traffic then the light will come on. So long easy throttle no check engine light, stop and go or hard throttle then i get the light. Please Help all advise is appreciated. Oh and to add jeep runs fine, no missing, no stumble of throttle, ruff idle, does not matter how much gas you have full, 1/2, empty it does not matter. Thanks
