If anyone asks where this came from...my Chrysler account was hacked.
Case Number 999922753
Vehicle Issue MIL on SAE P0123 | Check for voltage bleed over on the speed control switch sense circuit.;Follow all appropriate diagnostics for the fault that is present. Prior to replacing parts, please review the explanation below in the recommendation field.
System or Component DTC / Error Message;Group 18 - Vehicle Performance / Driveability,Throttle Position Sensor (TPS),Powertrain Control Module (PCM)
Recommendation Check all connectors between the speed control switch and the PCM for moisture Internally the PCM uses the same A/D (analog to digital) converter for TPS voltage as it does for the speed control switch sense. If the v-37 circuit has voltage bleed over from another source, a code of TPS Shorted to voltage may be set in the PCM. The DN model equipped with rear heat option, has an external water pump to circulate coolant to the rear heater. If you find coolant in the bulkhead connector, the likely cause would be a leaking coolant pump. Pump should be replaced if found leaking. If the code sets when the A/C is turned on go right to the PDC connector, C130, and check for moisture. Check for a shorted clock spring causing the speed control 5 volt feed to be shorted to power.
Modification Date 03/11/05 3:51 PM
