Check my gear pattern thread
orange150
Fairfax City, VA
I'm about ready to drop in the used 3.73 gears and carrier with a new spartan locker in the front D30 on my CJ. Before I start pulling my Jeep apart, which shim pack thicknesses should I start with? The ones from the donor axle or the ones from my axle?
I picked up an install kit plus a Lube Locker from ECGS. I don't think I need anything else other than time and gear oil to complete the install, hopefully in the next two weekends, at which point I will need someone to check my pattern :)
Use the ones from your current housing. Note the -/+ marking on top of the pinion. If the new one is the same as the old one (+1 for example), button it up with those shims.
For preload shims, you'll need between 55-60 thousanths.
Take a pic of the -/+ markings on each and PM me or post up, I'll tell ya mathematically what to do
D60u. The sharp lines at the bottom make me think I need to pull some pinion shim. Pull 3thou or run it? 0.008BL
Coast is showing a hair deep and drive is a hair shallow. Since the BL is in spec, if add 0.002" to center up the drive a bit. I wouldn't lose any sleep over being a little deep on coast. The pattern is very broad and gradual. It'll last a long time noise free
Five months later….
This is the CURRENT pinion.
This is the DONOR pinion.
You're reading off the coast side, which is what you have to do with a used gear.
The pattern is acceptable given the fact it's used.
Assuming the backlash and preload are ok, button it up
