01blktaco
- Apr 22, 2005
- Kernersville
hey man to get back on topic. If I were you, since the waggy axle isn't to much of an upgrade to the hp30 I would get a HP44 out of a late 70s ford f150, and shorten the tubes down and run waggy axles in it. Then you have a high pinion dana 44 that is close to your 60WMS.
If you wanted to go even further you could leave it full width since it is only 65"WMS and then run a matching 9" in the rear. Do a little backspacing and your setup won't be overly wide but it will be a little wider thus making it a litte more stable. Good luck with choice.
