ty20404
Member
- Feb 14, 2011
- Wilmington
Okay, I'm going to be as systematic about the details here as possible because I've got a baffling issue that I dearly need help on.
My idle drops to about 200 RPM when: I am braking without the vehicle in gear from any given speed. Typically happens MORE OFTEN and is more noticeable when: I'm going downhill OR from a higher speed than ~30 MPH.
Details on the vehicle: 1996 Cherokee Classic, AX-15, 4.7L Stroker. ~230K miles on body/trans, ~40k miles on engine (second hand Precision Engines crate motor). I have upgraded to a Comp Cams package (the one for Fuel Injection).
What I've done so far to TRY and fix the problem: Replaced Fuel Filter, Replaced Injector O-Rings, Replaced TPS with used TPS from my old 2000 XJ.
What I'm thinking: I'm thinking there's an issue with the fuel delivery system... I say this because I doubt there is a vacuum leak issue. I do NOT get any sort of idle issue while at a stand still and stepping on the brakes. Whenever I have the hood popped and I rev the engine up and release the throttle there is not a single idle issue what-so-ever. I also don't think it's the IAC valve because I cleaned the ever-living-shit out of it, and if it were the IACV I would probably notice idle issues across the board...
I'm thinking it's something having to do with the gas tank/fuel pickup/fuel pump but I have zero experience in this area, so any insight on where to start would be great.
