cherokee won't start
HAMMER502
norwood,nc
my 93 cherokee won't start.not real familiar with the electrical systems and any known issues.figured i'd ask here first.it has been parked for 5 months.new battery installed last month,but no spark.checked all connectors,no problems(visually).the tach does not move when cranking.any leads would be appreciated,gene.:driver:
So its not getting spark? Then i would say you need a new coil, or wires. But if you mean that all it does it crank but never turns over then i would say it time for the notorious cherokee crank shaft positioning sensor. Ps. the tach probly wont move untill the engine is running because the starter its turning the motor that fast so it wouldnt read since most tacks read in thousands.
also check the gas and the fuel filter if its been parked for some time, it might be as simple as its not getting enough gas from the fuel filter
