CoonDogger
- Aug 21, 2006
- Jacksonville, NC
After my roll the other night is when I assume it started.......... My alternator will not charge on my truck. I have taken it off two times and taken it to be tested. It puts out 14.2 volts for them on their little testing machines. It will only put out 2 volts for me on the truck. I have tested it on the truck with NOTHING hooked to the alternator. Just mounted and belt spinning and I only get 2 volts. I have hooked the wire up and turned on every electrical component I have, and I get 2 volts. I have taken all grounds off of the engine, and cleaned them up to where they shine. I ground the frame down and re mounted the grounding wire. I even ran a grounding wire from the alternator bracket to the frame......... I am lost and don't know what else to do. It's internally regulated, and only has about 10 hours on it.
Any ideas?
Any ideas?
