Chevy 350 starter problem
us_hick
Vale, NC
I've got a yj with a 350 and the starter wiring is screwed up from PO. Starter turns the motor over but while doing it it clicks. I replaced the starter relay in the jeep fuse block but still same problem. Does anyone know wht wires r suppose to be hooked up to the starter, colors of wires or anything?. Any info would be appreciated. New battery and starter installed with new cable ends on batt cables also.
Should be a large power cable runnin to the power post from the battery and then a small (16ish gauge) wire that is a switched hot runnin to the small post.
Yeah I got those two but I'm workin with the yj orig wiring cut up..I need a wire color or some info for the yj wiring harness..
