poncho-mike
- Mar 20, 2006
- Apex
Hi,
I've got a 78 GMC 3/4 ton 454 Suburban that I've had for almost twenty years. The rear end went out on it about six months ago. I had planned to get it back on the road, but I'm beginning to wonder if it's worth the effort. It's a 2WD.
I have a fairly new tranny in it (TH400) that I want to keep. I also have an older pickup I'd like to keep some of the sheetmetal for, so I'm thinking of taking it apart. The motor runs good and has good oil pressure, but it's got about 220K miles on it. It's a 78 model 2-bolt main. I put a new timing chain and oil pump in it about 45K miles ago. It had a rear main oil leak, so I installed a new 60 psi pump while I was replacing the seal. The bottom end was clean. I change oil every 3K miles.
Can somebody ballpark what a complete motor is worth, carb to oil pan?
Thanks,
Mike
Thanks,
Mike
