Cperry
- Apr 24, 2005
- Durham, NC
99 suburban 350 vortec has a #5 misfire. when i got it had new plugs, cap, wires and rotor replaced.
1. getting good spark to plug
2. Plug was wet when a pulled and was white as in no fire was happening in the cylinder.
3. Unburned fuel is exiting the exuast
4. No intake leaks from what i can tell, sprayed carb cleaner and listened.
5. ECM is sending a ground to injector, power source to injector is good.
6. Injector is releasing fuel pressure when jumped.
7. compression is at 175 psi, did a cylinder leak down test varified intake and exhuast valves are opening, also pulled valve cover and insured rockers were moving.
8. checked harness grounds good.
so basically i got fuel, fire, air, and compression but the biatch aint firing.
