Chevy guys
grainger03
Member
Wilmington NC
I recently rebuilt my motor and now when I drive down the road the motor misses I've changed just about all the sensors distributor plugs and wires can't figure out what it is
may have a rocker too tight.. maybe a vacuum leak.. does it idle fine.. then ride like hell when you take off?
is the distributor maybe off by a little in either direction? I had a Suburban one time that I put a motor in and I had that problem. come to find out I had 2 plug wires crossed and the distributor was just a bit off. it ran awesome after I figured that out.
I've checked the timing idk how many times and turn it a lil either way to see how the motor would act but same thing I can check the wires tomorrow but if I had some crossed wouldn't it miss while idling
I've heard of poeple putting the dist on 6 instead of 8 and that make it feel under powered.
