motobilt
- Jul 25, 2013
- Dothan, AL
LS/LQ Engine Mount Brackets Click Here!
Mounting a LS / LQ based engine in a tube chassis, Jeep, hotrod, ratrod or other application is made easier with these mounting plates. The plates are a builder part. You will be required to fabricate mounts to the plates. The brackets are CNC cut from 1/4" high strength steel plate. The brackets sell in pairs.
Small block chevy mount brackets click here!
Mounting a Small Block Chevy 350 in a tube chassis, Jeep, hotrod, ratrod or other application is made easier with these mounting plates. The plates are a builder part. You will be required to fabricate mounts to the plates. The brackets are CNC cut from 1/4" high strength steel plate. The brackets sell in pairs.
