RamblinMan
- Jan 14, 2015
- Raleigh
I just bought a 2011 CK10543. The VIN ID says it has both the Max towing package as well as the Z71 package. From my research and logically it cant have both, can it?
I am looking to find to max towing capacity. Some sites say 9500# and other sites say 10700#.
I also read in the manual that if it does have the max tow there is an integrated braking system, how do I know if that is there?
Below is the equipment list from the GM VIN Checker.
Rear axle, 3.42 ratio (Refer to Engine/Axle chart for availability.) (With (LC9) Vortec 5.3L V8 Engine, Requires (K5L) heavy-duty cooling package)
Suspension Package, Handling/Trailering, heavy-duty includes 46 mm piston monotube shocks and 36mm front stabilizer bar (Includes 36mm front stabilizer bar when (NHT) Max Trailering Pack is ordered.)
GVWR, 7000 lbs. (3175 kg) (Requires CC10753 models and (L9H) Vortec 6.2L V8 SFI engine and (NHT) Max Trailering Pack or CK10753, CK10953, or CK10543 models. Standard on CK10753, CK10953, or CK10543 models.)
Transfer case, electronic Autotrac with rotary dial controls (Requires 4WD models.)
Four wheel drive
Battery, heavy-duty 600 cold-cranking amps, maintenance-free with rundown protection and retained accessory power
Alternator, 145 amps
Frame, fully-boxed, hydroformed front section
Suspension, front independent, coil over shock
Suspension, rear 2-stage multi-leaf springs, semi-elliptic
Steering, power, rack-and-pinion
Exhaust, aluminized stainless-steel muffler and tailpipe
Four wheel drive
