Does anyone have any "tricks of the trade" for removing a steering arm from a 1988 chevy Burb front axle? It has the 3 studs with the conical washers....WILL NOT BUDGE
Heat will help, as long as you don't heat the washers. I've had luck with hitting straight down on it. It seems to cause the arm to bounce up a bit enough to get it started then an air chisle.
