Chevy transmission problems
woodyolin1
olin nc
I have a buddy with a 92 chevy with 5 speed maunual tranny. It will go in gear fine, but nothing happens. Sometimes when you let out on the clutch, it makes a real bad rattle sound, but will not do it all the time. I'm going to pull it tomorow, but was wondering if it might be pressure plate/clutch issue or transmission. Any thoughts?
sounds like either a clutch disc/pressure plate problem or possibly a hydraulic problem. is there fluid in the clutch master cylinder and does the slave move when you press clutch pedal? does the pedal feel ok?
