I have a 1983 cj7 and the light in the dash will not go off. When the ebrake gets let off the light dims but will not go off? Checked the fluid level think this might be it, was low and filled it. Any and all help would be grateful. Thanks
Got me a little stumped on that. Do you know if it is for the E-brake, or hyd. brakes? If unknown, try checking the switch on the E-brake, might can disconnect it temporally, & see if light goes out.
Your e brake needs to be all the way up. If it hangs down just a tad the switch will open and the light will be on. Mine did the same and a mounted a spring to the pedal arm and back to the lower lip of the dash so the pedal would stay all the way up.
I think the ebrake light is going off. When you pull the release the light goes from bright to dim. Looking at it in action makes methink it's not the e brake.
