uglyjeepoffroad
Registered Loser
- Mar 20, 2005
- Hickory, NC
I have '78 CJ front discs on the Commando. They stop really well, but when I was doing the swap, I let the master run dry. I replaced it with a '78 cj master and went through about a week of bleeding to get it to work. The rear never really did bleed, but I was able to drive it a little.
Now, I swapped in a new (rebuilt) '72 master to get back to the original that seemed to work better.
It bled great and the pedal firmed up nicely. I took it for a little ride and the pedal kept getting firmer with every stop. It tightened up to the point that the front brakes are dragging. I got it back to the house and, with it out of gear, I can't push it.
The front brakes are locked up totally.
I ASSume there is a residual pressure valve for the original drum setup, but I am not sure how to remove it.
Does this sound like what is happening?
