wranglerrambler Well-Known Member Joined Dec 28, 2006 Location oxford,nc Nov 24, 2010 #1 On a 97 TJ how can you disengage the clutch? (Translation how do you make it so you dont have to use it to crank the jeep)
RenegadeT no shirt,no shoes,no dice Moderator Joined Mar 24, 2005 Location Stokesdale-Greensboro Nov 24, 2010 #2 Did you look in the owners manual? I thought there was an empty fuse slot somewhere, you put a fuse in and it for 'clutch override'
wranglerrambler Well-Known Member Joined Dec 28, 2006 Location oxford,nc Nov 24, 2010 #3 dont think that works for a 97. not sure. A good friend said "unplug conector from clutch pedal and jumper the 2 pins of the plug." Assuming he found it online so i'm gonna try that. thanks
