Clutch tech
YJJPWrangler
Charlotte
Need a clutch for the Willys. Engine is a 4.3 mated to a SM420. I have a hydro bell housing. I will need pretty much everything except the clutch arm. I haven't bought a clutch since 2004 so I am a little out of the loop. Anybody have any recommendations on brand/specs/where to buy?
Thanks,
Zack
I just buy Luk. Order it from Rockauto. Matter of fact, I have one waiting to go in the other Jeep whenever we have an excuse to pull the motor or trans out of it.
X2 for luk. I run them in everything but my diesel.
I run centerforce. Has weights that increase the holding power at increasing rpm, but less pedal pressure is needed.
Much easier on my knee for a trail rig, while still getting the power to the ground.
Had the same disc and pressure plate since 05. Many miles of dd use and now trail use. Works great.
The last Centerforce clutch I bought was a Luk with little weights added to the pressure plate.
I will also need to buy a flywheel as well.
Looks like an 11" clutch is standard. Would the 12" HD clutch fit?
