Couple more tips:
If not using THC (but floating Z- axis) ... and even more important if using something like langmuir with manually set torch height
- slats must be kept clean to maintain the flatness of the work surface, as well the trash in the tray can push the slats up when fishing for parts. Means more maintenance. Even more important if using a dry bed. Water table doesn't stick as bad to the slats.
I've drained and flipped or cleaned my slats about 4 times in a year; about 5 gallons ($100 at local welding supply) of plasma quench in that time. I intend to have copper slats cut in sawtooth pattern soon, easiest cleaning.
- one drag of the tip or collision can end the consumables useful life quickly.
The everlast plasma consumable are pretty cheap $200 kit has lasted me over a year; have enough to get me through another month or so, but I don't cut everyday... I know Hypertherm is much more expensive, but likely last longer, idk firsthand.
- if you can swing it, a table drain and fill system is useful; to save the water when cutting aluminum, and the need to process the aluminum extensively before welding. The contamination to aluminum with the water/ quench is detrimental for tig welding. I have to process very quickly due to the contamination from the arc and water. And it will stain the aluminum badly if left for very long... overnight the bottom of the sheet will turn black!
