Coil spring mount buckets
fordtrucknut
bedford va
Best place to get coil buckets to mount tj coils to a dana 60. Let's here it guys
.There are several out there..who has best price and best quality
Depends on the front 60 (assuming its Ford) The 78-79 has the widest variety of options. The later gets tricky and from what I've seen its best to build an entire truss system since your driver side coil will land directly on top of the leaf mount. WFO concepts has you covered either way.
wfo is a nice piece. a complete deal from end to end!
Yeah I like their company a lot. I've spent a few thousand with them over the years. Only thing I've noticed is on their 80'+ truss for Ford 60 is it raises the coil bucket off the axle up like 4" over the tube, which in a low Jeep can be a problem even with stock coils. Not sure if this is a Jeep application or not but something to factor in. Other than that the kit is bombproof.
Yes. It is going in a yj ..tj coils 86 ford dana 60..I am trying to stay away from the truss route because as you mentioned it raises the vehicle up way high
