coil springs
yes, you can do it.... but i dont recommend it at all... the heat messes up the temperament, as well as the spring rate of the coil... that on top of it being highly dangerous to do so....
X2 do not do that they will break just get longer springs
na man do it.. it's the best way to get tons of lift for you jeep.. matter o fact get two stock springs and weld them together.. you'd be able to fit like 40 inch tires easy
Don't weld them just get some of those coil spring spacers at AA and use those to hold 'em together.
GO AWAY
