Coilover Springs Needed
R Q
Charlotte
I have Fox 14" 2.50" coilovers and ordered 200/200# springs for my front. They have me 2" high so I had some 125# upper springs and put them on and they are about an inch low. So I'm looking for some (2 each) 150# and/or 175# to borrow or buy for set up. Specifically need 14" length, 3" I.D. wide, and 150# or 175# top springs or both so I can try each out. I adjusted the 125"s some but when I jacked up the rear to work on them, the 125#s squished down significantly so I can't see them working out when I bash into some rocks to get my heavy pig over them.
I'm in Charlotte, so the closer the better.
Thanks
Thanks
I *think* that wide open design will work you to get the right springs for your setup. For some reason I seem to remember watching a video they had up a while ago about setting up coilovers, figuring out lengths, spring rates, etc. In that video they talked about sending you springs to try and you could swap them out until you get the right ones. My memory is foggy on the best of days, but it might be worth a call to them to pick their brains. You could also check with Diddy’s Big Block Race Shop.
This is the video I was thinking of. Sounds like they’re talking about buying shock/spring packages, not just the springs. Still might be worth a phone call 🤷‍♂️
I actually bought springs from a company that will swap them out but only for 90 days and I ran out of time. So just ordered some 175# and will see how they work out. I can swap them out if needed but I'm planning on these to work lol
I used Dave's Offroad Supply. Prices are good and they have a lot of options.
