Tech11
- Dec 7, 2007
- Greensboro
I've had a electrical gremlin in my jeep for some time now. I would let the jeep sit for a few days and it would be dead. I couldn't figure it out. I thought maybe it was my gps I wired up, so I disconnected it, same problem. I disconnected my winch, thinking maybe the wireless controller was doing something fishy, or I had some sort of other short there. Same problem.
I had the battery tested and it is 100% (no dead cells). The store said to take my alternator off and they could test it. I live in an apartment and they frown on parking lot mechanics, so for now that wasn't an option.
I was going to disconnect the negative cable and come back in a few days, hook it back up and if the jeep started it'd have to be the alternator (wouldn't it?). But I remembered hearing about testing the alternator for AC and that would show it had bad diode(s) doing something and causing an electrical drain.
While running the volt meter showed 12.9-13.9 v and it was all over the place, up and down.
Turned the jeep off and took the negative cable off the battery, I hooked up my volt meter,pos to alt pos, and neg to a good ground, set it to AC volts, and it was all crazy showing
O.L,12,14,20,07,O.L,06,14,12,O.L,19,06 etc
just all over the place. Isn't O.L overload? Doesn't this mean my alternator is fubared, or did I do something wrong?
