Loganwayne
#BTL
- Feb 15, 2013
- Clyde, North Carolina
01 f250 7.3 extended cab. Last year I replace all break pads rotors and shocks. This spring I replaced ball joints tie rod and drag link and steering stabilizer. Replaced all u joints on the rear axle. DIDNT replace the carrier bearing in rear driveshaft or u joints in the front driveshaft, or unit bearings or hubs. Truck also has new tires. Truck had an almost constant vibration before replacing u joints found one broke with no needle bearings now it only vibrates between 30-40
