control arm drop brackets
xj_crawler
kannapolis, NC
does ne one know if the rough country control arm drop brackets will work on a zj i know the rubicon express brackets do but not shure about the rough country it looks like the same bracket just about a 150 dollor diff can someone help me out here please.
Well there isn't a whole lot differences between either brands, in the way they mount. So if you already know the REs fit then the RCs should fit.
As Randy stated above they are almost the same only the RE brackets have a longer brace that runs along the underside of the frame back to where the crossmember is. If you would like to compare them he has the RC brackets and I have the RE brackets.
ok sweet i was lookin at rc kit cause its so much cheaper and costomer service tried to tell me it wouldnt work but i didnt c y not when its the same design except for the frame support
The price is why I went with RC drops. Scott's drops came with his kit. If you need to take a closer look give either one of us a shout.
